Disconnected Cooktop Electrical Wires -- A Mystery - Appliances - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 03:35 PM   #1
Disconnected cooktop electrical wires -- a mystery
Hi there. My Thermador GGCV30 cooktop electrical wires are not connected for some reason, and thus there is no spark.
I think when we moved in, the cooktop was not working and the electrician tried to fix it by direct wiring it. Hence the wires are stripped as shown here:
http://imgur.com/yTHif
I also have the severed wiring harness, male end:
http://imgur.com/Trpfe
As you can see, there are 3 black wires, 2 white, 1 green, and 1 red.
I don't have the female end.
Here's what I'm wondering:
- What is the wiring harness supposed connect to? I assume these wires should end up connecting to a the house electrical service, but how? Through a plug?
- What are my options for fixing this? Is there anyway I could direct wire it?
- Or is it likely that it is disconnected because some other part inside the cooktop is also broken and whoever owned it before didn't want to spring for a new one??
Thanks for the help!
tomsmyth is offline   Reply With Quote
Old 11-05-2012, 04:13 PM   #2
Missouri Bound's Avatar
www.searspartsdirect.com may have a wiring diagram for you.
Do you want it your way or the right way?
Old 11-05-2012, 04:31 PM   #3
Sadly not.
I'm thinking if I connect black and red to hot, white to neutral, and green to ground, I should be good? Worth a shot I guess?
Old 11-05-2012, 06:52 PM   #4
So I did as I said I might, and it seemed to work (the burner ignited), but then my partner pushed the "up" exhaust button (there are no exhaust units actually connected), and she felt a little jolt, and there was some smoke, and the flames turned green. So I think we destroyed something. The cooktop still works though. So I think I'm giving up on the igniters. I've unplugged everything.
Still though, any theories as to why this happened? All I thought I did was connect the wires to what they would have been connected to via the wiring harness....
Old 11-05-2012, 07:10 PM   #5
I think that a little more research would have done you well....glad you aren't an electrician.
Old 11-17-2012, 10:35 PM   #6
Rewards Points: 530
Did you leave any wires not connected? You did say she got a tingle, right?
Electrical wires near/touching supply ducts? Borgs8 Electrical 14 02-06-2011 07:57 AM
Electrical wires touching heating/air cond. tubes between joists yummy mummy Building & Construction 5 09-27-2007 05:59 PM
Moving oven and cooktop to island; need electrical advice worldtravelerall7 Electrical 3 06-17-2007 04:32 PM
Electrical Wires and Shower Stall Burat Electrical 10 05-03-2007 09:49 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
