#1 |
Dirty water backs up into Kemore Dishwasher
We have a Kenmore dishwasher, model 665.16462300.
It washes dishes fine. And if we use it every day it works fine. But if it sets a few days we find about 1/2" of water in the bottom that has a bad smell. The dishwasher drain has a high loop under the sind and then empties into the garbage disposal. I have run the disposal with the water in the sink running full blast and it does not cause it to back up into the dishwasher. I replaced the little flapper valve by the food grinder in the dishwasher but it did not make a difference. Is ther another check valve somewhere? Thanks! Ron |
#2 |
Tileguy
I don't think it is backing up I think it isn't draining properly to begin with. Somewhere there there should be a screen on the discharge to be cleaned I think. Not really sure. I've had that problem before and could always clear it by cleaning something somewhere.
#3 |
It's empty after a wash cycle.
I don't see any screens or check valves in the parts list. |
#4 |
Super Moderator
I'm going to move this to 'appliances'
New members: Adding your location to your profile helps in many ways.--M-- |
#5 |
#1 HAWKEYE FAN
what do you call a high loop? How much higher than the disposal outlet is it?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"........... |
#6 |
6 to 8" higher than the disposal inlet.
About 2.5" from the top rim of the sink. |
#7 |
Yeah, sounds like it's coming from sink. does your sink drain slow or do you fill it to the top for some reason-either could cause this...usually on that d/w there's a check valve [rubber flapper] built into the hose that connects to the hose from the d/w drain port-see if that's ok....another possibilty is; it's fresh water [from a weeping inlet valve] and your d/w is loaded with crud [happens to the best of familys] so the two mix...to check that;turn water off for a few days and see what happens.
| Display Modes | |
| Grossly insufficient water supply to toilet wasting water? | mysterylectric | Plumbing | 8 | 01-17-2012 12:19 PM |
| Water leaking out left side vent(?) of Dishwasher | Barkley Online | Appliances | 8 | 01-14-2011 01:42 PM |
| Solar hot water | indatom123 | Green Home Improvement | 0 | 12-19-2010 01:01 AM |
| Oil fired furnace and hot water heater question | steveinpa | Plumbing | 3 | 08-10-2010 09:42 AM |
| water borehole question | joeuser | General Discussion | 2 | 04-18-2010 11:33 PM |
