Diagnosing Kenmore Fridge Issue - Appliances - DIY Chatroom Home Improvement Forum
Old 08-22-2013, 02:37 PM   #1
Diagnosing kenmore fridge issue
Hello, I have a 10 year old Kenmore Coldspot side-by-side fridge/freezer. The unit stopped cooling after emitting three or four clicks, like the thermostat was kicking in and out. So I installed a new thermostat. This did not help.
Current situation: Motor runs, but does not cool.
What is my next step to diagnose this problem?
jahertz is offline   Reply With Quote
Old 08-22-2013, 03:18 PM   #2
Rewards Points: 2,240
This should probably be moved to the "Appliance", sub-forum.
rossfingal is offline   Reply With Quote
Old 08-22-2013, 03:24 PM   #3
Sorry, thought it would be a repair rather than an improvement. Is there a way to delete or move thread?
Old 08-22-2013, 03:32 PM   #4
An old Tradesmen
Rewards Points: 8,176
Click on the red circle with the exclamation mark in it. that is the report post button. Then ask that the thread be moved. And we will move it for you. Which I already did.
Good luck with your fridge.
Old 08-22-2013, 04:36 PM   #5
Rewards Points: 14,306
Going to need the model #.
Old 08-22-2013, 04:38 PM   #6
Rewards Points: 258
must be a kenmore thing....mine does it too...still runs and everything is cool in the fridge. I just try to ignore it. My fridge is about 3 years old with the freezer on top.
jburchill is offline   Reply With Quote
Old 08-22-2013, 04:46 PM   #7
What does not cool? The freezer, the fridge, both?
Old 08-22-2013, 05:30 PM   #8
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
clicking noises would indicate the compressor relay trying to start the compressor. Either you have a bad compressor or a bad relay, best bet is the relay. $25 part.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
jahertz (08-22-2013)
Kenmore Fridge warm, while freezer is cold mcv709 Appliances 4 07-03-2013 12:36 AM
Fridge Too Warm Then Too Cold - Help! marcus118 Appliances 3 06-27-2013 02:01 PM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 07:59 AM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 09:55 AM
