Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-19-2011, 12:28 PM   #1
determine whether or not a dryer heating coil is operable
How do I use the DMT7 multimeter to show if a dryer heating coil is working or no longer functioning?
John P. is offline   Reply With Quote
Old 07-19-2011, 12:49 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
2 ways to do it. either set it for ohms(safest way) and ohm out your element or set it for voltage, turn dryer on and check for 240 volts to the element.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-19-2011, 02:09 PM   #3
Ohm it out to see if it has continuity.
kb3ca is offline   Reply With Quote
Old 07-19-2011, 06:25 PM   #4
Tileguy
Bud Cline's Avatar
UNPLUG IT FROM ITS POWER SOURCE FIRST
THEN use your ohm meter.
It could also be one or both of the two resistors that are there. You can check them with your ohm meter also.
Old 07-19-2011, 10:49 PM   #5
#1 HAWKEYE FAN
dryers have thermistors and thermostats, not resistors
Old 07-19-2011, 10:52 PM   #6
Tileguy
Bud Cline's Avatar
What-ever !
I might have known.
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 08:20 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 01:09 PM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 06:30 PM
