Dents In S Steel - Appliances - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 01:15 PM   #1
Dents in s steel
Anyone know how to get dents out of a steel refrigerator door ?
Jus10britt is offline   Reply With Quote
Old 04-08-2013, 03:00 PM   #2
Rewards Points: 3,130
I hope somebody answers. I'd like to know myself LOL.
Old 04-08-2013, 04:11 PM   #3
Rewards Points: 12
I did a quick Google. Seems like dry ice is a fan favorite.
Dan
djlandkpl is online now   Reply With Quote
Old 04-08-2013, 04:38 PM   #4
Household Handyman
Rewards Points: 1,408
Warm the area with the dent with a hair dryer just a bit too warm to the palm. THEN apply the dry ice to the dented area. Usually (?) this will cause the metal to shrink and pull the dent out. Dry ice hard to find? Just use a regular ice cube. Dry ice just lasts longer per application. This works on small auto body dents also.
Old 04-08-2013, 04:45 PM   #5
Rewards Points: 744
Either of those suggesting ice and heat, have you personally had success with those methods?
Seattle2k is offline   Reply With Quote
Old 04-08-2013, 05:10 PM   #6
Rewards Points: 12
I've never tried it. I do know that it's done for auto body work.
Dan
Old 04-08-2013, 05:58 PM   #7
Oso954's Avatar
Rewards Points: 752
The heat & ice will work on rounded dents and pop them out. Unfortunately, a lot of door dents are caused by sharp corners on the object striking them. So the ding or crease will not come out.
You can try one of the outfits that advertise paintless dent repair for automobiles.
If your fridge is SS steel the results may not be as completely invisible as the repair on enameled finishes.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Thurman (04-10-2013)
Old 04-08-2013, 09:32 PM   #8
r0ckstarr's Avatar
Rewards Points: 1,996
While i have never tried it either, there are videos showing the process on Youtube of the mentioned heat and ice.
r0ckstarr is online now   Reply With Quote
Old 04-09-2013, 10:52 AM   #9
My dents are dings I guess (with point and not just round ) that's why I was doubting the ice and heat myself
Old 04-09-2013, 11:20 AM   #10
custom user
Rewards Points: 150
I have done it successfully by removing the interior panel and working a rounded tool through the foam to the dent. Careful and back and forth motions are the operative words. On a freezer door (top mount) I drilled a small hole in the bottom and worked the tool up to the dent, then filled the hole with silicone.
JasperST is offline   Reply With Quote
Old 04-09-2013, 07:02 PM   #11
Bill Kearney
Rewards Points: 1,174
Check on what a replacement door skin would cost. I've got to get a new one for our fridge, it had a shelf land on it during the move and creased it, but good. New skin is about $200. It'll be an adventure pulling the whole thing apart, I'm sure, but less than the price of a new fridge...
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Windows on Wash (04-09-2013)
Old 04-10-2013, 01:16 PM   #12
I didn't think about removing the skin . If I do that taping it out may be good enough at least better
Old 04-10-2013, 02:20 PM   #13
Bill Kearney
Yup, 'less worse' is often good enough.
Old 04-10-2013, 04:23 PM   #14
Strategically placed refrigerator magnet.
oldhouseguy is offline   Reply With Quote
Old 04-10-2013, 05:05 PM   #15
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 153
If it is not Stainless:
Why not sand the entire Door down, repair the Dents with Car body filler, prime the Door, then paint it again in any color you like?
They also have some Colors now that look like Stainless.
A replacement Skin cost about $500, by the way.
Cheers,
Deja-vue is online now   Reply With Quote
repairing small dents in stainless steel refrigerator door? BHeinrich Appliances 7 02-27-2012 06:09 PM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 09:39 AM
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Removing dents from stainless steel refrigerator tripower Appliances 4 02-27-2009 06:47 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
