Dehumidifying Laundry Room - Appliances - DIY Chatroom Home Improvement Forum
Old 10-19-2009, 06:12 PM   #1
dIYHell
Rewards Points: 150
dehumidifying laundry room
I have a launchry room on the bottom floor of my house. Its a small room about 4X8 and gets pretty humid always smells. I think this is due to the moisture from washer and dryer (which vents outside). Theres no easy way to put a cieling fan in, I was thinking I could get one that I could put in the wall where I have a chase that I can run the vent 15' to an outside vent in the attic. The other thought is if I could find a small humidier that I could put on a shelf or hang on a wall which I could plumb to drain outside.
My concern with the fan is that It needs to run whenever people are doing laundry room. I solved this problem in another laundry room by wiring the lights to the vent to be sure it was always on when someone was in the bathroom but this is not as easy to do in the laundry room thats why I was thinking maybe getting a dehumidifier thats always on, the only drawback is it has to go in a wall or mounted on a shelf above the dryer.
rocketdoctor is offline   Reply With Quote
Old 10-19-2009, 06:50 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Any regular dehumifier should do the trick. You can go the extra mile and have it drain to a floor drain nearby, but if it only gets humid when you do laundry you'll probably be fine with emptying the bucket when it gets full.
Old 10-19-2009, 06:54 PM   #3
dIYHell
Rewards Points: 150
some of those are pretty big and I have no floor space for one so have to install within wall studs or on a shelf, was wondering if anyone had experience with this
Old 10-21-2009, 12:31 PM   #4
Would an exhaust fan work for you ?
captainobvious is offline   Reply With Quote
Old 10-21-2009, 01:08 PM   #5
dIYHell
Rewards Points: 150
yeah it might, I need to buy one that can be mounted on its side and push air about 15' up.
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 10:08 AM
Laundry Room and half bath overhaul! gone_fishing Project Showcase 10 04-29-2008 07:08 PM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 10:35 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
