Dehumidifier Trips Circuit - Appliances - DIY Chatroom Home Improvement Forum
Old 07-18-2014, 03:12 PM   #1
Rewards Points: 192
Hi! I have a Maytag 45 pint dehumidifier that is about 10 years old. I have it plugged into a 20 amp circuit with the only thing else on it being the furnace (not the a/c, just the furnace). It's been working fine for 3 years at my new house and about 7 years at my old house. Just last week, it's developed an issue where after it is on for a few hours, it will trip the circuit. I know it's the dehumidifier because when I unplug it, the furnace (blower motor) works properly for days without any issues.
I unplugged it for about three days and took the removable filter out this-morning and vacuumed it out and tried it again. Shortly after, the circuit tripped again.
I was wondering if anybody has any ideas onto why the dehumidifier is tripping the circuit. Is it something that I can fix?
Thanks!
wiz561 is offline   Reply With Quote
Old 07-18-2014, 04:29 PM   #2
DIY staff
Rewards Points: 7,174
Have you tried it on a different circuit?
The blower on the furnace draws a lot of juice--the combination of the dehumidifier and the furnace blower might be more than 20 amps---one of the two units is drawing more power than it use to----if they have been working well on that circuit in the past.
Old 07-19-2014, 08:25 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Is it tripping the circuit breaker or a GFCI?.
Coastal South Carolina
Old 07-19-2014, 10:21 AM   #4
Rewards Points: 192
circuit
The furnace isn't on a GFCI; just a straight regular circuit. So, it was tripping a regular non-gfci circuit.
I took it all apart yesterday and cleaned it out really good. The coils had a layer of dust/dirt on them. I got some coil cleaner, a hose, and covered/removed much of the electronics.
This-morning, I plugged it into a GFCI outlet and the fan/blower started up fine, but as soon as the compressor kicked on, it popped the GFCI.
So now, I don't know if I got some water where it wasn't suppose to be and just needs to dry out, or if it was related to the original issue.
I'd like to keep this one and fix it, as new dehumidifiers are a couple of hundred bucks. But if there's an electrical/safety issue with it and possibly might do more damage, I am wondering if it would be better/safer to get a new one....
Old 07-19-2014, 10:30 AM   #5
A "Handy Husband"
rjniles's Avatar
Any convenience receptacle in an unfinished basement needs to be GFCI protected.
Since it trips a GFCI as well as a regular breaker, it has issues. replace it.
Old 07-19-2014, 04:55 PM   #6
Rewards Points: 192
Thanks for the responses. I think that I will bite the bullet and buy a new one... I really don't want to, but I'd rather not have my house explode.
This is a little off topic, but I think that code allows non-gfci outlets on furnaces, water heaters, and sump and excavator pumps. Now I will admit that the furnace is hard-wired in but I installed an additional outlet in the box for the humidifier and dehumidifier. I should probably swap this out for a GFCI soon...
Thanks!
Old 07-19-2014, 05:01 PM   #7
A "Handy Husband"
rjniles's Avatar
Thanks!
Those exceptions have been removed. WH is a hard wired appliance and does not need GFCI. Nor does a hard wired furnace.
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
Circuit for bathroom in the basement felipe_heidrich Electrical 4 08-26-2011 04:54 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Microwave trips GFCI on a different circuit! Frank Kolwicz General DIY Discussions 7 06-01-2008 08:48 PM
