Dehumidifier Quit - Appliances - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 12:38 PM   #1
Rewards Points: 107
Dehumidifier quit
I run a dehumidifier in my garage because I have bare steel in there most of the time. I had it on this spring and went out there and it was a big block of ice. Now the fan runs, but it doesn't remove any humidity. Is it worth messing with or time for a new one? TIA
thunderhead is offline   Reply With Quote
Old 06-11-2012, 10:29 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
buy a new one, dehumidifiers are pretty much a throw away item these days.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
thunderhead (06-12-2012)
Old 06-11-2012, 11:19 PM   #3
Missouri Bound's Avatar
Dehumidifiers work pretty much like air conditioners: when the refrigerant is low the coil will freeze up. And pretty much a disposable item.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Consumer Dehumidifier for 1000 sq ft encapsulated crawlspace? chazman113 HVAC 4 08-11-2011 08:57 AM
Running AC and Dehumidifier mscrankypants HVAC 7 05-23-2011 04:19 AM
Humidifier and dehumidifier on furnace loadie HVAC 2 12-07-2008 03:16 PM
Can I do this w/a dehumidifier? famdog Plumbing 7 10-31-2008 09:53 AM
dehumidifier INSTEAD of crawl space vents DangerMouse Building & Construction 29 07-29-2008 12:55 PM
