Dehumidifier In Basements - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-13-2014, 05:22 PM   #16
Rewards Points: 6,652
If at 40%, that is good, but a little too low. Should be really around 50-52%. Too dry you start getting Static Electricity.
Old 04-13-2014, 05:38 PM   #17
An old Tradesmen
Rewards Points: 6,098
Originally Posted by Amitabh View Post
the furnace vents outside via a PVC pipe. The humidity right now is 40%rh. But the basement is yet to be finished. I am thinking about the future, placement of grates (for intake and outtake) and finally level of humidity.
What i did notice in my basement (and going off topic), is that i only have one return opening in the entire unfinished basement and thats not even in the middle of the room, its off to one side.
I wonder if i installed at least 1 more intake - i think that should improve air movement and perhaps reduce humidity?
I will definitely install grates in the furnace room, just so air moves in that room
Does it also get its combustion air from outside via a PVC pipe? Do you have a gas fired water heater in the same room, if so where does it get its combustion air from.
installing another return could put the room into a negative pressure and increase humidity if it has to pull in outside air.
Old 04-13-2014, 05:57 PM   #18
Rewards Points: 326
hey - started a thread in HVAC now - dont want to hijack my own thread
but to answer your question
combustion air is from outside for both Furnace and Water tank.
Amitabh is offline   Reply With Quote
Old 04-13-2014, 06:44 PM   #19
An old Tradesmen
If they draw air in from the outside. then putting a dehumidifier in the furnace room and installing connecting vent to the other room/rooms, it will defeat the purpose of the dehumidifier.
Old 04-13-2014, 09:54 PM   #20
Rewards Points: 1,674
My dehumidifier is in the furnace room, but its intake vent has been extended to the main room. So, the Dehumidifier is taking air from the main room, and delivering back to the main room (minus the water of course).
The machine is in the furnace room merely to cut down on the noise, which you can still hear... just not nearly as loud. It's also easier for me to run the drain hose there since the main stack is right beside the furnace.
Bob Sanders is offline   Reply With Quote
Old 04-13-2014, 10:28 PM   #21
cj133's Avatar
Rewards Points: 308
Bob,
What did you do for a trap? I had looked for a solution for this years ago and all I could find was doing a basic standpipe for a cloths washer which seemed a bit much. I ended up using a little giant condensate pump that pumps it into my backyard.
cj133 is offline   Reply With Quote
Old 04-14-2014, 05:04 AM   #22
An old Tradesmen
As long as the connecting vent is not communicating to the furnace room also, that works.
Old 04-14-2014, 06:40 AM   #23
a tidbit...keeping the furnace fan running in the off season helps keep the basement air circulating plus it sucks all the cool basement air into the upper living space. You will need to turn on the a/c less often.
creeper is offline   Reply With Quote
Old 04-15-2014, 06:42 AM   #24
Originally Posted by cj133 View Post
Bob,
My dehumidifier has been placed on a shelf about 4 feet up so that it can drain into the stack with straight gravity. A simple U bend was placed in the hose which forms a sort of P trap. It works fine.
Old 04-15-2014, 06:50 AM   #25
You should keep it running pretty much all the time anyway. There is a concern in basements over Radon gas, particularly in our part of the world.
Still, even with the blower on there is that cool, basement feel to the air as you go down. Dehumidifiers kill that issue completely. It feels like a true extension to the house. The air is warm and dry and welcoming.
Old 04-15-2014, 11:54 AM   #26
Rewards Points: 768
I've heard from HVAC guys that running your furnace fan year round will kill your furnace in no time at all. I'd contact a professional HVAC person to confirm whether or not running the fan is a good option.
cibula11 is offline   Reply With Quote
Old 04-15-2014, 12:45 PM   #27
An old Tradesmen
Won't kill the furnace.
It does however tend to raise the humidity in the house in the summer as it will re-evaporate some of the water of of the cooling coil(evaporator).
If a basement has a radon problem, but no radon removal system. Then the duct system should be sealed from the basement.
Old 04-15-2014, 04:38 PM   #28
I have to replace my blower motor about every three years. Last one I stuck in cost something like $68 plus tax.
Dehumidifier Amitabh HVAC 1 07-24-2013 08:56 AM
Help with dehumidifier location!! (weep holes?) ryanatw General DIY Discussions 1 04-20-2013 12:47 PM
My dehumidifier just died and I need a new one strategery HVAC 3 04-12-2013 05:14 PM
Whole-house dehumidifier installation? mahohmei HVAC 0 11-26-2012 09:42 AM
Consumer Dehumidifier for 1000 sq ft encapsulated crawlspace? chazman113 HVAC 4 08-11-2011 09:57 AM
