Dehumidifier Attached To Furnace - Appliances - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 11:29 AM   #1
Dehumidifier attached to furnace
Can a dehumidifier be attached to a furnance that can do a three floor home (2500 sq ft/floor)?
kerandel is offline   Reply With Quote
Old 10-12-2010, 06:04 PM   #2
Rewards Points: 282
This sounds like a problem that is usually solved with central AC. It may be more worthwhile to deal with the cause of the humidity which may lead to a better solution. Dehumidifiers work well in older basements which tend to collect dampness due to older construction methods. It seems like the rest of the house shouldn't suffer if air circulation and ventilation are adaquate.
Jim F is offline   Reply With Quote
Old 10-12-2010, 06:11 PM   #3
Rewards Points: 6,652
Yes, it is called Central Air Conditioning.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
