Defeating Defrost Cycle - Amana Fridge - Appliances - DIY Chatroom Home Improvement Forum
Old 06-20-2013, 06:30 PM   #1
Rewards Points: 16
Defeating defrost cycle - Amana fridge
I have a limited understanding of how refrigerators are kept frost free.
I have an Amana fridge model #DRB2101. Sometimes I am away from the cabin for a month or two at a time. It seems a needless waste of energy to have a heater come on, melt any frost, then cool down whatever was heated up. If the fridge door is not opened for many days, there should be little moisture that condenses and turns into frost, right?
Would it make sense to defeat the defrost cycle for periods when no one is using the fridge? Is it worth it? If so, I would like to find out how to do this.
Thanks in advance!
saltpeter is offline   Reply With Quote
Old 06-20-2013, 06:55 PM   #2
Rewards Points: 13,300
Far more is wasted having a fridge no one is using even running while no one is there, empty it, shut it off prop the door open.
Old 06-20-2013, 07:03 PM   #3
Rewards Points: 16
Thanks for the suggestion. I do that when I know I will be gone a long time. But I don't always know whether it will be a few days or a few weeks.
Cabin is out in the middle of nowhere in central Minnesota.
Old 06-21-2013, 01:11 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
your worrying for nothing, a refrig that gets little or no use will use a very small amount of electricity on the defrost cycle. If the doors are not getting opened then very little frost will build up on the coils, the less frost the shorter the time the heater will be on. The defrost cycle is controlled by a defrost timer and a defrost thermostat. The thermostat controls how long the heaters actually stay on.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Tempstar heat pump won't initiate defrost cycle lgmccoy1 HVAC 14 12-08-2011 07:07 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 11:52 PM
