Cutting Hole In Side Of Stove Rear Recession For Gas Access - Appliances - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 12:51 PM   #1
Rewards Points: 1,062
Question
cutting hole in side of stove rear recession for gas access
this is obviously a retrofit.
i can get my gas line under the sink cabinet, which is next to the stove, but not behind and into the wall to reach the stove where it expects it because the wall behind is brick/plaster.
so i was wondering if it is reasonable to cut a small bay in the side wall of the stove recession (the caved in area where the gas and power sockets are) so that the gas yellow hookup hose and the power cable can go through there to reach the supply line and power receptacle that are under the sink cabinet.
see illustration.
thanks
cutting hole in side of stove rear recession for gas access-gas_stove_side_supply.jpg
Old 07-14-2012, 01:40 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by amakarevic View Post
...wondering if it is reasonable to cut a small bay in the side wall of the stove...
What does reasonable mean?
Obviously it's possible...
Old 07-14-2012, 01:44 PM   #3
well, you know, is it something that would throw off a home inspector and such?
i cannot figure out why they don't make small access openings on the sides of the access recession for retrofitting purposes like this. it is not always easy/possible to situate a gas terminal exactly behind the stove...
Old 07-14-2012, 09:25 PM   #4
Rewards Points: 83
As far as I can remember in the gas code (canada) you cannot pass a flexible hose through any kind of wall. I don't have a code book infront of me, so I cannot confirm.
Where does the gas pipe go originally? How large is it? How are you tapping into it? You need to make sure that your pressure drops aren't too high or else you can have problems with your range.
Protocol. is offline   Reply With Quote
Old 07-15-2012, 07:09 AM   #5
MarginallyQualified
To be sure.
I did it once for an illegal MIL apartment.
I wouldn't do it again though.
Open the sheet rock, drill some studs and reroute the pipe.
Old 07-16-2012, 02:43 PM   #6
This is how it all looks. The stove is all the way against the wall. Works fine.
Old 07-16-2012, 07:47 PM   #7
Rewards Points: 83
I hope you checked for leaks.
Old 07-16-2012, 07:52 PM   #8
MarginallyQualified
That's bloody awful!
Old 07-16-2012, 07:54 PM   #9
no leaks
Old 07-16-2012, 07:55 PM   #10
it is a temporary solution until i redesign the kitchen. sorry if it looks ugly to you. but it works and there is no leaks. it is below the sink so who cares as long as it works fine.
consider not being a hater
Old 07-16-2012, 09:26 PM   #11
Rewards Points: 83
I've seen worse.
My only concern is stated above as possible code violation. And the reason I said check for leaks is since it is in an enclosed space.
Old 07-16-2012, 09:35 PM   #12
Hey... it works and the house is not in flames
cutting hole in side of stove rear recession for gas access-forumrunner_20120716_223554.jpg
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 11:55 AM
Door Knob Hole Cover Plate One Side ice Carpentry 5 06-30-2011 01:18 PM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 09:13 PM
Cutting Vent Hole in Roof How To Wanted wildbilly Plumbing 17 06-02-2010 04:35 AM
Plaster wall - cutting out an access hole, but how to replace it? Steelmesh Building & Construction 8 11-07-2008 09:40 AM
