-   -   cutting hole in side of stove rear recession for gas access (http://www.diychatroom.com/f47/cutting-hole-side-stove-rear-recession-gas-access-150228/)
amakarevic 07-14-2012 12:51 PM
1 Attachment(s)
this is obviously a retrofit.
i can get my gas line under the sink cabinet, which is next to the stove, but not behind and into the wall to reach the stove where it expects it because the wall behind is brick/plaster.
so i was wondering if it is reasonable to cut a small bay in the side wall of the stove recession (the caved in area where the gas and power sockets are) so that the gas yellow hookup hose and the power cable can go through there to reach the supply line and power receptacle that are under the sink cabinet.
see illustration.
thanks
TarheelTerp 07-14-2012 01:40 PM
Originally Posted by amakarevic (Post 965550)
...wondering if it is reasonable to cut a small bay in the side wall of the stove...
What does reasonable mean?
Obviously it's possible...
amakarevic 07-14-2012 01:44 PM
well, you know, is it something that would throw off a home inspector and such?
i cannot figure out why they don't make small access openings on the sides of the access recession for retrofitting purposes like this. it is not always easy/possible to situate a gas terminal exactly behind the stove...
Protocol. 07-14-2012 09:25 PM
As far as I can remember in the gas code (canada) you cannot pass a flexible hose through any kind of wall. I don't have a code book infront of me, so I cannot confirm.
Where does the gas pipe go originally? How large is it? How are you tapping into it? You need to make sure that your pressure drops aren't too high or else you can have problems with your range.
TarheelTerp 07-15-2012 07:09 AM
To be sure.
I did it once for an illegal MIL apartment.
I wouldn't do it again though.
Open the sheet rock, drill some studs and reroute the pipe.
amakarevic 07-16-2012 02:43 PM
1 Attachment(s)
This is how it all looks. The stove is all the way against the wall. Works fine.
Attachment 54250
Protocol. 07-16-2012 07:47 PM
I hope you checked for leaks.
TarheelTerp 07-16-2012 07:52 PM
That's bloody awful!
amakarevic 07-16-2012 07:54 PM
no leaks
amakarevic 07-16-2012 07:55 PM
it is a temporary solution until i redesign the kitchen. sorry if it looks ugly to you. but it works and there is no leaks. it is below the sink so who cares as long as it works fine.
consider not being a hater
Protocol. 07-16-2012 09:26 PM
I've seen worse.
My only concern is stated above as possible code violation. And the reason I said check for leaks is since it is in an enclosed space.
amakarevic 07-16-2012 09:35 PM
1 Attachment(s)
Hey... it works and the house is not in flames
Attachment 54261
