Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-28-2010, 01:23 PM   #1
Question
Culligan Water softner
I have a Culligan Mark 100 Soft Minder water softener and I came home one day to the sound of water running continuously; and after "looking" for the source found it to be the water softener. Sounds as though the water softener was stuck in the regeneration mode where it flushes the water to the plumbing to be drained into the sewer system. Any ideas of where to start on how to fix this? We have really hard water where I live and am afraid of having to replace all other appliances that relies on softer water. I have tried to regenerate manually and it goes as far as flushing to the sewer and only does that. Any suggestions would be helpful and will try...
1Harley is offline   Reply With Quote
Old 08-31-2012, 09:50 PM   #2
where's the answer to this????
jt6749 is offline   Reply With Quote
Old 09-01-2012, 04:17 PM   #3
crankcase's Avatar
I would guess that that the piston has siezed up or something may be lodged in the valve. Check the linkage from the motor to the piston arm for broken components. Do you have sediment at all in your water? We had a similar problem with a purchased unit and it was about $300 for a plumber service call to rebuild the valve. The rebuilt unit bit the dust after another year. Now we rent our units from culligan with no charge for service calls if needed.
http://cassidywater.com/service/Mk100_Serv_98_2000.pdf
crankcase is offline   Reply With Quote
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
water softner repair ranchody General Discussion 3 05-28-2007 01:41 PM
