Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-09-2012, 04:12 PM   #1
culligan medalist water softerner
has been working fine. i had to reset the date after a power outage - the softener had been working only regarchign in middle of the day - and as i reset the timer, i accidently set off the regen...now the water will not stop flowing after 80 minutes! i had to hit bypass to turn it off. the water coming out of the drain is very salty and the water tank seems super high with water...think water is just pouring in and continuining to flush the resin beads - maybe the float isn't tell it to stop???
lahomeowner27 is offline   Reply With Quote
Culligan Water softner 1Harley Appliances 2 09-01-2012 04:17 PM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 03:47 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
