Creaking - Whirlpool Duet Front Load Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 07:00 PM   #1
I have a Whirlpool duet front loading washer and it seems to be making a squeaking noise during low RPMs when the washer spinning slowly.
It's usually very silent when the drum is spinning slowly. But it just started doing this on a medium-sized wash.
During the spin cycle however there is no additional noise.
The washer is about two years old and it's been working flawlessly until this point.
I didn't notice any extra noises like a strain on the motor or leaking anywhere. It just sounds like a high-pitched scratching or creaking.
Are there any common problems for this washer? Is this an easy fix? Has anyone experienced the same problem? Is total failure imminent?
Thanks! Homer
homerb is offline   Reply With Quote
Old 01-03-2012, 07:31 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
have a service tech check it out for you, so many things it could be. Maybe the pump, maybe tub bearing, drive belt, motor, maybe something stuck betweeen the 2 tubs and rubbing? Hard to say without hearing it. No real issues or problems with the duets
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
Old 01-03-2012, 11:30 PM   #3
Well if he keeps getting worse I'll just tear apart and see what's going on back there. Maybe it's a belt. Maybe it's a bad bearing. Or maybe there's just a bunch of dirt and cried back there. I just ran a self clean wash where the rotor would spend without anything edit and it didn't make any noise at all.
LG Front Loading washer on second floor Mr Chips Appliances 11 10-20-2012 09:23 PM
Whirlpool Creaking Ice Maker ambar Appliances 1 06-12-2009 11:01 AM
Front Load Washer handy man88 Appliances 3 07-01-2008 11:16 AM
Whirlpool Duet tryinitmyself Appliances 4 03-17-2008 01:07 PM
Recommendations on Front Loaders Washer/ Dryer helpless handyman Appliances 6 02-15-2008 11:59 AM
