Craftsman Air Compressor Motor Spurts At Higher Pressures - Appliances - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 11:14 AM   #1
Craftsman air compressor motor spurts at higher pressures
I have a Compressor, 1.5 HP, 2 gal, 125 psi, electric. It will build up to 50-70 psi and then motor begins to labor, spurt and then stop, It just started this. Changing the regulator does not help.
dunlaple is offline   Reply With Quote
Old 08-30-2010, 12:19 PM   #2
Rewards Points: 24
Sounds like it is still building pressure, but that it in the head, rather than sending it to the tank. I would start with the check valve, if so equipped, which would be located in the line from the head to the tank, and if not that, it's most likely a bad valve in the head.
Congoleum higher end vinyl vs. lower end counterparts buhockey Flooring 1 10-30-2009 09:56 PM
Craftsman 19.2 problems..please help lairdness Tools 12 08-17-2009 10:14 AM
Need held adjusting Craftsman Band Saw and Belt Sander tripower Tools 2 12-13-2008 09:23 AM
Replaced section of subfloor but it's 1/16" higher. Is that a prob? Piedmont Carpentry 1 08-29-2008 11:12 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
