-   -   Craftsman air compressor motor spurts at higher pressures (http://www.diychatroom.com/f47/craftsman-air-compressor-motor-spurts-higher-pressures-79930/)
dunlaple 08-29-2010 10:14 AM
I have a Compressor, 1.5 HP, 2 gal, 125 psi, electric. It will build up to 50-70 psi and then motor begins to labor, spurt and then stop, It just started this. Changing the regulator does not help.
DexterII 08-30-2010 11:19 AM
Sounds like it is still building pressure, but that it in the head, rather than sending it to the tank. I would start with the check valve, if so equipped, which would be located in the line from the head to the tank, and if not that, it's most likely a bad valve in the head.
