Craftsman 5.5hp Snowblower - Appliances - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 05:20 PM   #1
Craftsman 5.5hp snowblower
Trying to repair the snow blower after last winter, and found that there are three bolts that hold the ball bearing retainer to the auger housing. How do I get behind the impeller to do this. Or, how can I remove the spring pins from the shaft to get behind the impeller?? Any help would be much appreciated.
B. Sirbaugh is offline   Reply With Quote
Old 01-25-2011, 04:53 PM   #2
Rewards Points: 133
Pictures?
Are you trying to replace the bearing? And if so, is it the one between the motor and auger, or the ones on each side of the auger blades? if if it the first, then you need to split the case of the blower by taking the belt cover off, removing the belts, then removing the bolts that hold the Auger housing to the Motor frame. Once this is done, they should be two separate pieces. From there, you'll need to remove both pulleys off the auger shaft (if 2 stage) and then you should be able to remove the bolts for the bearing retainer, and replace the bearing.
jimmyfloyd is offline   Reply With Quote
Snowblower Repair FF_Thor General DIY Discussions 0 11-29-2010 04:51 PM
Craftsman Snowblower only runs on choke tjm0852 General DIY Discussions 9 04-16-2010 05:59 PM
Craftsman snowblower problem joeg679 Landscaping & Lawn Care 12 04-10-2010 08:22 PM
Craftsman 19.2 problems..please help lairdness Tools 12 08-17-2009 10:14 AM
Craftsman snowblower model # 536.918200 ttocsnosretep Automotive Repairs 1 12-19-2008 10:38 PM
