Converting Electic Stove To Gas Stove - Appliances - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 10:13 AM   #1
converting electic stove to gas stove
I want to covert my electirc stove to a gas stove, I do have a gas hot water heater right below where the stove will hook up. Will this make the conversion easier?
susan2 is offline   Reply With Quote
Old 02-19-2011, 10:39 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,370
Ayuh,... I assume you mean Replace the electric stove with a gas stove,..??
If so,... Sure, yank out the electric stove, run a gas line, 'n hook it up to the new gas stove...
Bondo is online now   Reply With Quote
Old 02-19-2011, 11:03 AM   #3
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Look into the new induction ranges, you may want to skip gas, especially as its cost keeps going up.
Sent from my Samsung Vibrant using Android DIY Chatroom
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 02-21-2011, 08:03 AM   #4
It can be not that simple. there are line sizes to be considered..after you know what you're actualy dealing with-post in plumbing section as that's their trade..
Jacques is offline   Reply With Quote
Old 02-21-2011, 09:23 AM   #5
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Oh it's definitely not simple, both of us are over simplifying the process just to show it can be done. Even switching to induction range which I HIGHLY recommend vs. gas will require new wire and a 50 amp breaker.
Single post questions tend to be trolls. As a result spending time on detailed answers generally isn't necessary.
--Chris the DIY Guy
Converting Gas Stove to an Electric Stove? LooptieLu Electrical 8 01-07-2011 10:20 AM
Converting electric stove to gas - HOW? styler1010 Electrical 10 05-31-2010 01:22 AM
Converting Electric to Gas stove LaurynJohnny Appliances 16 03-26-2010 08:08 PM
converting maytag stove to nat gas tiger76 Appliances 0 01-31-2010 01:46 PM
Converting from Gas to Electric Stove Chloe Appliances 1 06-14-2008 03:06 PM
