Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-04-2013, 06:05 PM   #1
Connect Grill to Home Propane
We just moved to a house that has a spot to hook up our grill to the home's propane source. There is a shut off, then a flexible hose with a flare fitting on the end. I cannot, for the life of me figure out what i need in order to hook it to my grill. Maybe I'm making this harder than it is. Any help?
cibula11 is offline   Reply With Quote
Old 01-04-2013, 06:16 PM   #2
Simple adaper is all you need.
http://image12.bizrate-images.com/re...5578&mid=19035
Something like this.
cibula11 (01-04-2013)
Old 01-04-2013, 06:21 PM   #3
Guywithskills
If u cannot find off the shelf at Ace hardware. Take both ends if you're not sure, go to RV store, most can make it for you. Custom length and the fitting of choice on each end all gas rated (gas rate important). This can be done for not much more than if found on the shelf. Best part is custom length.
Guywithskills is offline   Reply With Quote
Old 01-04-2013, 06:49 PM   #4
Thanks. I'll check out the store next time I'm in. So, the female end would connect to the male flare fitting that exists on the flex pipe, but how does the male end of that adapter fit on my grill? Can I keep the hoses and regulator that is on the grill or do I need to get rid of it?
Old 01-07-2013, 09:34 AM   #5
Does anyone know if there's a fitting that would connect a acme( currently on the grill-large black plastic fitting) to a 1/2" flare? Can't seem to figure this out.
Old 01-07-2013, 12:29 PM   #6
Without seeing it it is hard to tell. I will assume that you have a standard propane tank hookup on the grill right now. That hose has a flared coupling connector on the end that is attached to the grill control valves. It is posible that the flare fitting on the hose from your supply has the same thread and "may" be able to be connected that way.
However, I would find a way to put a shutoff valve in that line near the grill so you do not rely on the grill's valves to shut off the gas when you are not using it. They are not the most reliable valves.
If you are unsure of this, contact your propane distributor. I am sure they have someone there that can help you. They also have a vested interest in ensuring you do not blow yourself up due to a faulty connection.
danpik is online now   Reply With Quote
Old 01-07-2013, 02:00 PM   #7
Missouri Bound's Avatar
Contact your local propane distributor for help. They will have the correct fittings, and will do the installation for you if needed. You will need a regulator at the grill as well.
Do you want it your way or the right way?
Securing propane grill for hurricane? thinksincode General Discussion 9 10-28-2012 10:20 AM
Adding Propane To Existing Home firebird0095 Plumbing 0 06-01-2012 02:06 AM
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
