Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-22-2013, 07:16 PM   #1
Concord 80 plus not firing
The green light pulse 3 times at a time, don't know what that means, it doesn't fire up, I switched the gas and power off and on , nothing happened, any ideas??
abunabil is offline   Reply With Quote
Old 01-22-2013, 10:31 PM   #2
http://www.askmehelpdesk.com/heating...es-601743.html
Could be pressure switch. Large silver disklike item with hoses attached.
Carefully disconnect hoses and blow into them to clear. Some people use a paperclip if really gunked up.
Check for obstructions to air intake and exhaust.
Should be posted in HVAC section for more results.
diyorpay is offline   Reply With Quote
Brand New Concord Furnace Doesn't Work In Cold Weather LeighC HVAC 21 01-07-2013 09:48 PM
anyone ever hear of concord furnace? THEBIGPUNN HVAC 16 10-03-2012 12:16 PM
Concord Furnace Leaking Behind Panel of Heat Exchanger bettyRubble HVAC 5 03-05-2011 03:49 AM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
