Compressor Heating Up - Appliances - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 06:34 PM   #1
compressor heating up
Haier ESR042PWW mini fridge compressor gets hot replaced start cap, same thing any ideas?
ropermedical is offline   Reply With Quote
Old 03-01-2011, 09:40 AM   #2
Static condenser?? shuts off on overload?? runs ok but hot to touch?? air clearance ok??...other than that=bad compressor.
Jacques is offline   Reply With Quote
Old 03-02-2011, 05:32 AM   #3
Compressors get hot. It's what they do. A compressor takes low pressure, low temperature gas and compresses it to a high temperature, high pressure gas. This in turn goes to the condenser where it is converted (condensed - think of condensation sweating on your favorite cold beverage) to a liquid. This liquid is sent to the expansion device (often an orifice valve) where it becomes a vapor and sent to the evaporator as a low pressure, low temperature gas which is what cools the refrigerator and the process starts over again.
This is a highly simplified explanation. However, the OP gave a highly simplified description of their concern.
If the unit is otherwise functioning properly, and the only concern is that the compressor is "hot", I don't really see a problem.
Perhaps the OP can follow up with more information.
yarddawg is offline   Reply With Quote
