Compact Fridge Not Cooling - Appliances - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 04:44 PM   #1
Household Handyman
Rewards Points: 1,408
Compact fridge not cooling
So, someone gives me a fairly new "Magic Chef" compact fridge unit. They used it to keep wine cool and it stopped cooling, less than two years old. I know nothing about fridge's other than they are to keep beer cold. The compressor does vibrate as if it is working, but it does not cool the inside of the unit. Is there a way for a fridge techy to check the freon and add freon if necessary? I see not fittings for this. It may be another problem, I just need an idea of if it would be worth it to have someone check it out. Thanks, David
Old 10-07-2010, 06:12 PM   #2
HVAC / Plumbing
This relay may be bad at the compressor
kenmac is offline   Reply With Quote
Old 10-08-2010, 09:15 AM   #3
if the comp is running but no cool it's not worth fixing..EPA rules you just can't add R and even if you did, these are criticaly charged so it wouldn't last anyway. only way is to find and repair leak but that's real involved and requries $$$ equipment.
Jacques is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Fridge not cooling - evap fan? oppiecat Appliances 4 07-02-2013 05:19 PM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 08:59 AM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-23-2008 12:36 AM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 11:52 PM
