Comfortmaker Furnace Model #EPD30B15C2 - Appliances - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 11:58 PM   #1
Can I get a manual for troubleshooting since I was not provided one by the home builder
Karen Moran is offline   Reply With Quote
Old 11-02-2011, 12:01 AM   #2
I still want an answer, can I get a manual for this model furnace from this web-site?
Old 11-02-2011, 12:02 AM   #3
This was useless! I'll go elsewhere.
Old 11-02-2011, 09:14 PM   #4
Hi, sorry you didn't get a response sooner. We hvac guys hang out in a different area of this site.
To answer your question; there are not any manuals that are available to the general public.
What kind of problem are you having?
Master of Cold is offline   Reply With Quote
Old 11-03-2011, 12:56 PM   #5
You responded to my request for a manual so that I could do some troublshooting on my own. I understand that the manual is not available to the general public.
I cannot get my furnace to turn on. So far, I have tried shutting everything down from the circuit breaker and resetting it but that did not have any effect. When I attempt to turn on the eight year old furnace it does nothing. Not a sound.
Can you help to troubleshoot this problem
kmoran451 is offline   Reply With Quote
Old 11-03-2011, 03:16 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
Start with the obvious, make sure you have high voltage to the furnace, check the breaker. Than the fuse on control board, then transformer...
Doc Holliday is offline   Reply With Quote
Old 11-03-2011, 03:53 PM   #7
raylo32's Avatar
Rewards Points: 1,238
As for basics, don't forget to verify or check/change the thermostat batteries, if any.
raylo32 is offline   Reply With Quote
Old 11-03-2011, 04:04 PM   #8
How do I replace the fan blower belt.
kmoran is offline   Reply With Quote
Old 11-03-2011, 04:25 PM   #9
There's got to be bolts that you loose to take tension off. Or you can turn by hand while prying the belt off. Watch your fingers.!
Old 11-03-2011, 04:50 PM   #10
raylo32's Avatar
Quite the leap from "basics" to replace the blower belt. Maybe it's broke so there will be no tension to remove.
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
bryant model 393-U furnace Gary Atkins HVAC 1 02-13-2011 08:36 PM
Comfortmaker Furnace GUH075A012IN Jim123 HVAC 0 01-05-2011 07:32 AM
ducane furnace model cmpb100caa does nothing, light on gas valve indicates all ok daveandoliver HVAC 5 11-06-2010 09:36 AM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 09:24 PM
