-   -   Comfortmaker Furnace Model #EPD30B15C2 (http://www.diychatroom.com/f47/comfortmaker-furnace-model-epd30b15c2-122108/)
Karen Moran 11-01-2011 10:58 PM
Can I get a manual for troubleshooting since I was not provided one by the home builder
Karen Moran 11-01-2011 11:01 PM
I still want an answer, can I get a manual for this model furnace from this web-site?
Karen Moran 11-01-2011 11:02 PM
This was useless! I'll go elsewhere.
Master of Cold 11-02-2011 08:14 PM
Hi, sorry you didn't get a response sooner. We hvac guys hang out in a different area of this site.
To answer your question; there are not any manuals that are available to the general public.
What kind of problem are you having?
kmoran451 11-03-2011 11:56 AM
You responded to my request for a manual so that I could do some troublshooting on my own. I understand that the manual is not available to the general public.
I cannot get my furnace to turn on. So far, I have tried shutting everything down from the circuit breaker and resetting it but that did not have any effect. When I attempt to turn on the eight year old furnace it does nothing. Not a sound.
Can you help to troubleshoot this problem
Doc Holliday 11-03-2011 02:16 PM
Start with the obvious, make sure you have high voltage to the furnace, check the breaker. Than the fuse on control board, then transformer...
raylo32 11-03-2011 02:53 PM
As for basics, don't forget to verify or check/change the thermostat batteries, if any.
kmoran 11-03-2011 03:04 PM
How do I replace the fan blower belt.
Doc Holliday 11-03-2011 03:25 PM
There's got to be bolts that you loose to take tension off. Or you can turn by hand while prying the belt off. Watch your fingers.!
raylo32 11-03-2011 03:50 PM
Quite the leap from "basics" to replace the blower belt. Maybe it's broke so there will be no tension to remove.
