Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-01-2007, 06:58 PM   #1
comfortmaker flame sensor
I have A comfortmaker furnace. The draft motor turns on,glow plug lights,burners fire up. After about 7 seconds burners go out and the blower motor never turns on. I thought the flame sensor was bad,cleaned up with emery an installed,same problem. My question is can you test the flame sensor with an ohm meter. right now I have 0.4 ohms put A propane torch flame close to the end and my reading stayed the same.Is this flame sensor good or bad.
big ron is offline   Reply With Quote
Old 11-02-2007, 10:20 AM   #2
Sounds like it is bad. They are fairly cheap, replace it.
cjett is offline   Reply With Quote
Comfortmaker furnace problem dragon2125@hotmail.com HVAC 2 12-07-2008 02:12 PM
Flame blowin' in the wind... testeng HVAC 4 10-28-2007 04:11 PM
weatherking furnace blower runs continuously rayborj HVAC 4 12-08-2006 03:23 PM
carrier 58SX ignition problem typhoon55 HVAC 5 06-08-2005 10:18 PM
flame sensor tbristolb HVAC 3 04-10-2005 10:06 PM
