Coils Freeze Up - Appliances - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 04:18 PM   #1
coils freeze up
Ok, So I have been working on a 1930s ice box converted into a kegerator. The way it was built is an inside shell made of metal. Insulation all around it and then another metal shell around all that made of metal (here is the link to how i built it. It is kinda long http://www.homebrewtalk.com/f51/plea...erator-404933/) I had to take it apart and replace the insulation and I put a cooling system in it from a dorm fridge. The fridge had cold coils on the back and hot coils on the side. It didn't have the tray that most minifridges have. At first I put the cold coils taped to the back of the inside metal shell of the fridge, and the hot coils on the outside against the outer shell on the sides. I sealed off the inside. I could only get the fridge down to about 55-60 degrees. I then cut out the inside back and moved the coils to inside the kegerator and added two layers of foam board to the inside.
The bottom three coils keep freezing up so I figure I need to get more airflow over them to transfer heat out of the kegerator. i would like to get the temp down to at least 40 but I understand the cooling system was made for an enclosure that is 2-3 times smaller. So it might be a lost cause. Does anyone have any suggestions on how I can get it colder without having to take it entirely apart and get a bigger cooling system?
Sorry about no pictures, but I don't see any buttom to upload a pic of my computer.
humpadilo is offline   Reply With Quote
Old 06-03-2013, 08:49 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
if your using a dorm refrig cooling system, it is way undersized
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
dirty heat exchange coils diylogin HVAC 2 08-08-2011 09:11 PM
Heat coils on same time w/ AC reevtd HVAC 9 03-09-2011 04:58 PM
Seer 10 evap coils bad, Go to Seer 13??? pcumming HVAC 5 09-01-2010 05:21 PM
Coleman Leaky Coils rdwacw HVAC 1 07-15-2010 10:30 PM
Coils in flower shop freeze? delta HVAC 6 06-21-2010 04:12 PM
