Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-18-2007, 02:01 PM   #1
Default Clothes Washer Will not start cycle
Whirlpool 8200 series, about 12 years old.
Worked yesterday, today nothing. Confirmed that power at outlet is at 120V. Checked lid switch for continuity and it's good too. Dial selector/timer switch will not engage at any point in any cycle.
What should I check next?
allenzachary is offline   Reply With Quote
Old 02-19-2007, 12:26 PM   #2
I'm no repair person but one time the inside of the plastic knob stripped out and so the little spindle thing couldn't turn. Does the plastic knob turn freely? If so it's about $15.00. If it is the timer, could be about $80 + installation by the washer guy. Check the internet [have your model number ready, everything seems easier to research with it.]
Good luck
shapeshifter is offline   Reply With Quote
Old 01-25-2008, 11:18 PM   #3
Default Kenmore washer will not start
Did you find a resolution? My Kenmore 80 Series washer is doing the same thing -- it simply will not start all of a sudden. I checked the plug, the fuse, the pipes, the dial, the tub... what could this be? It worked just fine last night, but this morning... nothing. Any hints?
amgar88 is offline   Reply With Quote
Old 01-25-2008, 11:40 PM   #4
I wish I could tell you the solution. My guess was a loose connection somewhere in the top of the console. I removed the console, wiggled all the wires, (which all seemed tight and making solid connections) then frustrated, put it back together. Once it was reassembled I plugged it back into power, just to confirm it was still dead. Ba da bing. It was working again and has ever since. Weird. I can't tell you at all what was wrong. Could have even been the main 120v plug was partially out of the wall socket. I have no idea....
Old 01-26-2008, 11:58 AM   #5
Thanks for your reply. I did the same thing last night, following lots of online diagrams and advice columns. I had the same outcome... wiggled some wires, made sure everything was tight, cleaned out a few years of gunky soap that had dripped into the console... and this morning I am doing laundry again. I feel like I conquered the thing, without knowing what the heck I did, so it's a win with an asterisk next to it.
Old 01-27-2008, 02:07 PM   #6
Sweet! Glad I could help...such as it was.
Happy laundering!
More On This Topic
Hi! This is John on behalf of Expertvillage.com. In this video clip I will be showing you how to reconnect the spark plug wires. When I go to reinstall the spark plug wire back onto the spark plug what I like to do is blow a little compressed air into... Read More »
In this clip we're going to talk about the proper way to remove and replace a burned out headlight on a 2000 Dodge Stratus. In this step we're going to talk about the proper way to reassemble your light bulb to the retainer to the electrical connection... Read More »
On behalf of Expert Village my name is Seth Williams. I work for D - K Service. I'm here to tell you about simple street bike brake repair and inspection. After you get the connecting rod out of your master cylinder you need to disassemble this to get... Read More »
From Expert Village, I'm Kurt Glaser talking to you KGB Studios Seattle. Well, now that we've got all four tracks laid, what we want to do now is learn a little bit more about the mixer. The mixer is where you mix it all together. Let's take a look at... Read More »
Internet Cable Problems
Internet Cable Problems by Expert Village
Hi! I’m Mike with expertvillage.com today what I’m going to be doing is talking about some of the reasons why your internet connection may not work. Here’s our handy dandy cable modem, which looks all well and good. We’ve got a... Read More »
Washer drain peloncito Appliances 7 08-04-2007 02:56 AM
Kenmore Top Load Washer gone Crazy ! kourso Appliances 1 07-09-2007 01:48 PM
dish and clothes washer drainfield rosiesunimind Plumbing 1 02-11-2007 06:41 PM
Comfortmaker GNL won't start Hollandpiper HVAC 2 10-10-2006 04:37 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 11:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
