Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-14-2012, 09:17 AM   #1
Clothes washer filling with water??
Model: Kenmore Elite HE3 front loading automatic washer (2003)
Issue: This morning I found my clothes washer full of water to the bottom of the front loading door. In fact, because we leave the door open between uses, it had leaked out and soaked the rug in the laundry room underneath the machine. When I mentioned it to my wife, she responded that this had happened a few times recently, and she just ran the drain/spin cycle to get rid of the water.......(thanks for telling me!)
Has anyone ever experienced this? My initial assumption is that the pump supply valve has a failed/damaged check valve, allowing water to get in when not in use. If I can narrow down the issue, I will fix it myself (as I have done in the past.) However, it being winter finally, I have limited time/space to mess with it, so if I can't narrow it down, I might have to call the appliance guy.
Any useful advice is appreciated.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 01-14-2012, 09:39 AM   #2
Disabled wood vet
titanoman's Avatar
Call the appliance guy.
titanoman is offline   Reply With Quote
Old 01-14-2012, 01:07 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
most likely the problem is the water valve. Water is probably trickling in when not in use.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-14-2012, 02:02 PM   #4
That's my thinking as well. But the parts schematic does not show a supply valve as a unique part. I am assuming it is part of either the motor control unit, or the pump.
There are no other issues, and the machine still washes clothes...
Old 01-14-2012, 02:07 PM   #5
Follow where the supply lines come inside the washer. There's going to be two solinoid valves, On top of them there's going to be two wires each.
That's were it will be leaking through.
1910NE (01-14-2012)
Old 01-14-2012, 03:07 PM   #6
http://www.ifixit.com/Answers/View/3...+what+is+wrong
1910NE (01-14-2012)
Old 01-14-2012, 04:59 PM   #7
Joe, I think that is exactly it! Thanks a bunch.
I will order the part, and make the repair. Stay tuned for the results.
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
LG Washer not putting water in the drum RuralPrincess47 Appliances 4 07-28-2010 01:50 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
