-   -   Clothes washer filling with water?? (http://www.diychatroom.com/f47/clothes-washer-filling-water-129905/)
1910NE 01-14-2012 08:17 AM
Model: Kenmore Elite HE3 front loading automatic washer (2003)
Issue: This morning I found my clothes washer full of water to the bottom of the front loading door. In fact, because we leave the door open between uses, it had leaked out and soaked the rug in the laundry room underneath the machine. When I mentioned it to my wife, she responded that this had happened a few times recently, and she just ran the drain/spin cycle to get rid of the water.......(thanks for telling me!)
Has anyone ever experienced this? My initial assumption is that the pump supply valve has a failed/damaged check valve, allowing water to get in when not in use. If I can narrow down the issue, I will fix it myself (as I have done in the past.) However, it being winter finally, I have limited time/space to mess with it, so if I can't narrow it down, I might have to call the appliance guy.
Any useful advice is appreciated.
titanoman 01-14-2012 08:39 AM
Call the appliance guy.
hardwareman 01-14-2012 12:07 PM
most likely the problem is the water valve. Water is probably trickling in when not in use.
1910NE 01-14-2012 01:02 PM
That's my thinking as well. But the parts schematic does not show a supply valve as a unique part. I am assuming it is part of either the motor control unit, or the pump.
There are no other issues, and the machine still washes clothes...
joecaption 01-14-2012 01:07 PM
Follow where the supply lines come inside the washer. There's going to be two solinoid valves, On top of them there's going to be two wires each.
That's were it will be leaking through.
joecaption 01-14-2012 02:07 PM
http://www.ifixit.com/Answers/View/3...+what+is+wrong
1910NE 01-14-2012 03:59 PM
Joe, I think that is exactly it! Thanks a bunch.
I will order the part, and make the repair. Stay tuned for the results.
