Clothes Dryer Quit - Appliances - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 10:09 PM   #1
clothes dryer quit
I was drying clothes today, went to put in the last load n it wouldn't start up again.. checked power going into the unit and the breaker any suggestions.
bjohnson1325 is offline   Reply With Quote
Old 03-13-2013, 10:25 PM   #2
Rewards Points: 14,306
Make and model?
Old 03-13-2013, 10:31 PM   #3
Frigidaire electric model fee700fhso 120/240vdc 60 Hz 23 amps
Old 03-13-2013, 10:46 PM   #4
What do you mean it wasn't coming on?, can you be more specific? Like it doesn't tumble, it doesn't heat up, if it has light on the inside does that come on, if it is a digital display does that come on?
First thing I would do is find the door switch (the pin switch that moves when you shut the door) and manually push it in and out with the door open and ready to run, maybe tap (don't get to carried away with it cuz you don't wanna break it) it a little bit and continually push it in and out and see if that is the problem since that is the easiest to test, if it kicks on then get a new door switch
second, UNPLUG the unit and make sure all your wiring connections are good and tight
Does this have a digital display or is it the old turn style?
third if none of these work UNPLUG THE UNIT and take off the back panel and look for any burnt up or wires that came loose, if the back doesn't come of then you will have to take whatever you need to to get to the wiring to inspect it. Most of the time you can look up how to take apart your specific model on youtube
Last edited by rugerduke; 03-13-2013 at 10:47 PM. Reason: needed to add a safety statement in the text
rugerduke is offline   Reply With Quote
Old 03-13-2013, 10:55 PM   #5
Thanks for the info its the old turn style ,the light turns on and off with the door switch, no burnt wires , all connections are tight, it doesn't start up no heat no tumble
Old 03-13-2013, 10:59 PM   #6
so your door switch works if the light comes on, so did you take off the back panel to inspect the wires. ALso you might check the start button? maybe that switch is bad. Can you hear the motor running when you hit start? because if you can't then it could be a broken belt or tensioner and it might not heat up if there is a safety in it if the tumbler doesn't spin. The last sentence was me just thinking out loud.
Old 03-13-2013, 11:07 PM   #7
Yes I've removed the back panel no burnt wires nothing visible on the circuit boards, belt is good everything turns , and everything is tight.
Old 03-13-2013, 11:09 PM   #8
I can hear the timer kick in if I hold the on switch in the on position but nothing else happens
Old 03-13-2013, 11:11 PM   #9
That model # does not come up.
http://www.repairclinic.com/RepairHe...er-won-t-start
Old 03-13-2013, 11:13 PM   #10
Sorry its fee700fhso
Old 03-13-2013, 11:14 PM   #11
either the start switch or the motor is burnt up because if I remember right the wiring goes through the motor then to the heating element. DO you have a multimeter to see if power is going into the motor?
Old 03-13-2013, 11:16 PM   #12
Nope just a pin tester
Old 03-13-2013, 11:27 PM   #13
Thanks joecaption for the link it looks vary helpful.
Old 03-20-2013, 08:25 PM   #14
Hey borrowed a muti-meter n found the thermostat and thermal fuse were defictive. That repair clinic was vary helpful. Thanks
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Clothes Dryer Duct Repair nordfish Appliances 2 08-12-2012 10:07 AM
Clothes Dryer Ventalation crankbait09 HVAC 6 07-03-2012 06:24 PM
Clothes Dryer Ducting Earnie Plumbing 1 11-30-2010 10:38 AM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
