Clothes Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 01:29 PM   #1
clothes dryer
How do I remove the outer panels/casing of my Whirlpool Imperial Series dryer?
Mrs. Goodwrench is offline   Reply With Quote
Old 02-24-2012, 02:06 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
why would you want to? every repair can be made by either removing the rear panel or the front.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-24-2012, 03:40 PM   #3
Rewards Points: 144
If this is what you are trying to do, start with the front panel. On many models today, there will be two screws that hold the front panel in place, ususally not in plain sight, because they are concealed by the fact that they are along the bottom edge of what otherwise appears to be a decorative lip or trim. If you find those, remove them, and the front panel should swing out, and you should then be able to release it from the clips at the top of the panel. Before doing this, make sure that the breaker or fuse panel is switched OFF, the fuses are pulled, or that the dryer is otherwise de-energized.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
clothes dryer sucking all my cool air outside shank General DIY Discussions 6 08-02-2012 09:01 PM
Water damage in laundry room re: clothes dryer outlet mcbutterpants Electrical 3 02-07-2011 09:33 PM
Clothes Dryer Ducting Earnie Plumbing 1 11-30-2010 10:38 AM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
