Clicking Sound: Changed Relay: Not Cooling So Well - Appliances - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 12:53 PM   #1
Clicking Sound: Changed Relay: Not cooling so well
Hello Gentlemen
I woke up and heard my whirlpool fridge making clicking sounds and the compressor was very hot to the touch. I did a bit of research on the forums and found out it could be the start relay. It was last minute and I needed it right away. I called our local appliance store and he didnt have the oem part but sold me some 3 in 1 kit for $75!! Later I find out that these are junk so I did order the OEM one.
After I installed the 3in1 the fridge works and I feel cold air coming into the freezer. The problem is, its not cooling enough. I left it all night and the freezer water didnt turn to ice. I checked the OHM levels on the compressor and they all seem fine. I also cleaned all the coils.
Does anyone have any ideas? I try not to post questions but I am completely stumped and im hoping the compressor isnt broken.
I would greatly appreciate it your help
Thank You
tmushy is offline   Reply With Quote
Old 02-16-2011, 03:47 PM   #2
Rewards Points: 530
I think I would check the fan that cools the compressor.
Old 02-16-2011, 08:35 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
3 in 1 relays are not junk, they are just not meant to stay in place of the OEM, with that said if the compressor is running and both fans are running you may have a refrigerant leak.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-16-2011, 09:51 PM   #4
Rewards Points: 530
Aren't the 3in1's meant to be boosters for weak compressors?
Old 02-16-2011, 10:48 PM   #5
#1 HAWKEYE FAN
yes they are ,3 in 1 is a 1) start relay, 2) overload, 3) start capacitor Use them all the time, there is no way anyone could possibly stock every realy and overload combination for every compressor. The 3 in 1 will work on every one of them until you can get an OEM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
Clicking Sound in Walls Jend Plumbing 3 03-05-2008 10:05 AM
Roof repair related to clicking sound in ceiling/walls? smittyruns Roofing/Siding 3 01-26-2008 10:15 AM
Clicking sound in walls leted_82 Plumbing 7 10-16-2007 06:25 AM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
