Cleaning Stainless Steel Appliances? - Appliances - DIY Chatroom Home Improvement Forum
Old 01-18-2014, 11:04 AM   #1
Rewards Points: 562
Cleaning stainless steel appliances?
In the past, I've found that Pledge works really well, but over time it starts to buildup a yellowish haze. I've recently discovered that rubbing alcohol not only removes the waxy buildup, but it actually works really well for removing grime and fingerprints. Plus, it gives the appliances a shiny, streak free appearance, similar to when they were new. In fact, I've recently ditched the Pledge in favor of rubbing alcohol.
My question is, will prolonged use of rubbing alcohol damage a stainless steel finish.
kcrossley2 is offline   Reply With Quote
Old 01-18-2014, 09:25 PM   #2
Rewards Points: 266
Alcohol is a potent reducer preventing/removing oxidation on/from the surface of the steel. In other words, it removes that fine sacrificial "rust" coat (chromium oxide) that protects the steel from further damage, hense stainless steel. Unless you rub clean stainless steel that is exposed to sea water, most likely you won't notice any damage in your lifetime.
At least now you know why it looks so clean!
nanuk is offline   Reply With Quote
Old 01-18-2014, 09:28 PM   #3
Rewards Points: 562
Good to know. Thanks!
Stainless steel formica trim mystery Bunburryist2 Kitchen & Bath Remodeling 2 08-03-2013 02:34 AM
installing stainless steel sink in granit counter top? DJFlynn92 Kitchen & Bath Remodeling 5 02-10-2012 09:35 PM
Installing Range Hood and Stainless Steel Backsplash oguevarra Remodeling 1 02-26-2010 04:01 PM
Removing dents from stainless steel refrigerator tripower Appliances 4 02-27-2009 05:47 AM
cleaning stainless steel appliances? Yeti Appliances 3 12-11-2007 09:30 AM
