Check Your Clothes Dryers. Safety Hazard! - Appliances - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 05:47 PM   #1
Dave Sal's Avatar
Rewards Points: 634
Check your clothes dryers. Safety hazard!
I was drying clothes yesterday in a 7 year old Kenmore Elite HE4 gas dryer. After about 20 minutes of drying time I happened to walk into the laundry room to get something and smelled a slight odor of something burning. I opened the dryer door and could tell it was coming from there. The clothes were almost dry so I turned it off and decided to open it up the following day (today). I had already cleaned the dryer exhaust vent last year (sheet metal, not the cheap foil or plastic kind) so I knew that was probably not the issue. Attached are two pictures taken as soon as I got the back panel off, and two pics after I cleaned it up. They speak for themselves. I should have had a smoke detector in the laundry room before but never did. I'm on my way to the hardware store to pick one up as soon as I post this.
Check your clothes dryers. Safety hazard!-img_2590.jpg   Check your clothes dryers. Safety hazard!-img_2591.jpg   Check your clothes dryers. Safety hazard!-img_2595.jpg   Check your clothes dryers. Safety hazard!-img_2596.jpg
Dave Sal is offline   Reply With Quote
The Following User Says Thank You to Dave Sal For This Useful Post:
gma2rjc (03-18-2013)
Old 02-19-2013, 05:53 PM   #2
I think we have gas driers in my building's laundry room. I went upstairs after putting the clothes in the dryer. A while later I checked the security camera and saw that it looked cloudy in there. I figured there was a problem with the camera, but when I went back down there I smelled gas in the lobby and laundry room. If you have a gas dryer you should probably get a CO detector too.
Dorado is offline   Reply With Quote
Old 02-19-2013, 07:33 PM   #3
Rewards Points: 22
I take my dryer apart once a year to clean out any lint in the cabinet. I also remove and clean the area where the filter resides. Damp lint sticks to everything.
djlandkpl is online now   Reply With Quote
Old 03-12-2013, 02:01 PM   #4
Rewards Points: 27
I should have taken a picture of my gas dryer last month when I discovered it was full of lint. The lint screen chamber (or whatever it's called) got clogged with lint and caused humidity and carbon monoxide to be exhausted into the laundry room. I got that cleared using a long brush and then took the back off the cabinet. What I found was the cabinet was PACKED FULL of lint. Not just coated like the original poster's dryer - it was packed to capacity. Couldn't even see the motor or any of the components.
The dryer is 18 years old and had obviously never been cleaned out before. I bought the house 1.5 years ago and never even thought to check the dryer for lint. Now I will make sure I inspect/clean every 6-8 months. Not taking any more chances; that was a major fire hazard and I feel terrible for not even thinking to inspect it. The previous owner was elderly and did not do one tiny bit of cleaning or maintenance to her appliances.
nezwick is offline   Reply With Quote
Old 03-17-2013, 09:57 AM   #5
Household Handyman
Rewards Points: 1,408
Operating a "HandyMan" type business I do get calls concerning appliances. I get calls occassionally about dryers not heating "properly" and find that most of these calls involve the dryers exhaust ducting system is clogged. While I am cleaning the duct work I do inspect the inside of the cabinets and find a build-up of lint such as this. It amazes me how some people are sitting on a potential fire hazard although they do not know it. Let's face this: We use our clothes dryers as needed, not thinking about a problem, such as lint build-up until there is a problem. Another potential problem I see is that there are some of those dryer sheets which have certain chemicals within them that will coat the screen of the lint screen so that air cannot move through them efficiently. I place the lint screen under the kitchen faucet, add a little water to show them how the lint screen will hold water with this coating. I then show them how to wash this screen and recommend that they do this about every four (4) months or so. Actually, I put mine in the dishwasher to clean it, works for me.
The Following User Says Thank You to Thurman For This Useful Post:
Old 03-18-2013, 12:24 AM   #6
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
If you have pets, better check and clean the dryer out frequently, because not only the lint collects in the flue and cabinet, but dog and cat hair from your clothes and especially blankets have static that really attracts loose hair.
RWolff is offline   Reply With Quote
Old 03-18-2013, 08:07 AM   #7
Rewards Points: 6,652
Your smoke detectors are probably not the Photocell type. I would suggest going with those over the others that that can take up to 35 min's to go off. Photocells only take up to 17 min's max before going off.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Homeowners And Safety. Roofmaster417 Roofing/Siding 0 05-03-2011 11:41 PM
2 clothes dryers exhaust vent icandoanything HVAC 4 11-28-2010 02:21 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Multi-Wire Branch Safety check Please!! kuhiomall Electrical 12 05-16-2008 08:08 PM
