Which Is Cheaper To Run - Appliances - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 11:41 AM   #1
Question
Which is cheaper to run
I have a room off my detached garage that is 200 sq. ft and a vaulted ceiling about 14ft at its highest point.
I have a window air conditioner/heat pump that when on heat is 240v/15.5 amps. it has a thermostat, but the fan runs 24/7. This unit takes no time at all to bring room to temperature.
I also have a portable oil filled radiator type heater they is 110v/12.5 amps and thermostically controled (no fan). this maintains tempereature, but the heat elements seem to com on a lot.
My question is - which is cheaper to run on a 24/7 basis?
CritterOH is offline   Reply With Quote
Old 11-17-2010, 06:38 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
the a/c unit would be way cheaper, but why would the fan run all the time. I think there should be a setting that the fan turns off with the compressor.
hardwareman is offline   Reply With Quote
Old 11-18-2010, 07:29 AM   #3
Thanks for the reply
unfortunatley there is not. it has a temperature control and then the control to set it to:
Off
Cool High
Cool Low
Fan High
Fan Low
heat
220 vac cheaper that 120 vac scottkolu Electrical 15 09-30-2009 10:15 PM
Cheaper By The Floorin jebilger Flooring 2 06-09-2009 12:33 PM
Is it actually cheaper to.......??????? MrShadetree0222 HVAC 21 10-11-2008 12:11 PM
Is Power cheaper with 200A Service? Dave-Denver Electrical 19 08-27-2008 12:45 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 01:31 PM
