Changing Light Switch Thermador Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 06-12-2012, 05:29 PM   #1
Rewards Points: 168
http://www.appliancepartspros.com/pa...73&NewWindow=1
Hi: I have a Thermador Wall Oven Model CT127NW. See diagram above.
It is part #3. Light switch button.
The push button for the light switch control on the front panel is broken. I have found the part but it in't clear how to access the part.
There is a Glass control panel that has the Temp Control, Thermometor, Timer, etc. including the switch for the light. There are no screws at the control panel.
It looks like I can take a few nuts that are holding a few of the controls on the outside of the glass plate off and then pry it carefully off.
Since the parts diagram for this model does not show how the control pieces are accessed would anyone know if there are mounting screws behind the glass plate that will give me access to change the switch?
I do not want to pull this apart and find there is no access. also I can't imagine I have to pull the oven from the wall to repair it.
Thanks,
Tom
roztom is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 01:16 PM
