Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-27-2010, 05:07 PM   #1
changing ge dryer vent from back to right side
New here.. have just ordered a new dryer. Need to change the vent from back to right side. Has anyone done this before...any hints, tips, suggestions or "NOT to Dos" would be appreciated. Thanks
msavage is offline   Reply With Quote
Old 05-27-2010, 05:28 PM   #2
Xtreme DIY'r
You want to go out the back & vent to the right out the house ?
Use an elbow
Or you want to change the dryer itself to vent out the side of the dryer ?
Never see one that can do that
Old 05-27-2010, 06:22 PM   #3
can't use an elbow out the back..no really enough room..have to change the vent to the right side. They say there is a kit but I haven't been able to find the diagrams or anything and just wondered if anyone had done something like this before and how difficult it might be
Old 05-27-2010, 10:15 PM   #4
fabrk8r
fabrk8r's Avatar
Would this happen to be a GE Profile dryer? If so you can buy the kit for $14.99 and from what I've heard it takes about 15 minutes to install the kit.
There are other GE dryers that allow side venting also, but I don't know which models.
There are knockouts on the side of the dryer.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-28-2010, 09:20 AM   #5
Household Handyman
Most of the dryers I have run across do have "knockouts" pre-stamped into both the left and right sides of the cabinet. Remove the knockout from the side to be used, save the sheet metal piece even if bent. You will probably have to access the actual dryer ducting by laying the unit on it's front side, pad the floor to prevent scratching. Remove the factory venting from the motor area, replace with the new 90º bend, you will probably have to use some straight duct to reach the cabinet wall. I like to allow the duct to stick out 1/2" - 3/4" to attach the remainder of the ducting. Flatten the old knockout piece, if necessary, and use it along with duct tape to patch the hole in the back of the cabinet--just because. There is a little more to this task, but in short terms that is how it's done. It's not Rocket Science and a competent DIY'er can do this. Good Luck, David
Old 05-28-2010, 09:33 AM   #6
Average Joe/ex-Navy IC3
gregzoll's Avatar
They actually make a duct that is rectangular for when you have or need a tight fit.
Old 05-28-2010, 12:45 PM   #7
Thanks all..David Thurman your explanation sounds great..ok I will give it a try..dryer arrives on Tuesday. Salesman said they wanted $135 to do it at the store because it was difficult..doesn't sound that difficult and I am usually pretty handy so time will tell. marilyn
Tags
appliances, dryer vent, electical, general discussion
Dryer vent with 4" PVC pipe rjniles Appliances 30 07-01-2010 09:21 AM
attach bathroom fan vent to dryer vent hohadcr HVAC 9 03-08-2010 06:58 PM
Dryer vent backdraft damper BlueCrystalMan Building & Construction 4 01-01-2010 03:26 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
Dryer vent path Cossack HVAC 1 01-14-2009 09:57 PM
