Changing 3 Prong Range From Hard Wired Stove - Appliances - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 03:00 PM   #1
changing 3 prong range from hard wired stove
how can I change 3 prong stove from hard wired stove?
Maggiemoos is offline   Reply With Quote
Old 06-14-2011, 03:05 PM   #2
Experienced
Jackofall1's Avatar
Welcome Maggiemoos, to the best darn DIY'r site on the web.
No matter how good the site is, it is difficult to respond to some questions.
Are trying to install a stove that has to plug, or are you trying to hardwire a stove that has a plug.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Maggiemoos (06-14-2011)
Old 06-14-2011, 03:09 PM   #3
the stove is old. it has been installed with hard wire cord. I am getting new stove with 3 prong in it.
how should i do that?
Old 06-14-2011, 03:19 PM   #4
r u there?
Old 06-14-2011, 03:26 PM   #5
Experienced
Jackofall1's Avatar
You will have to purchase a female recepticle which matches the plug and wire the old hard wire connection to it. This is not a difficult task, make sure you power down the breaker to the stove and then check for voltage before attempting any changes.
Mark
Old 06-15-2011, 06:33 AM   #6
if it's 3 wire cord make sure grd strap[on range] is connected to neutral.
Jacques is offline   Reply With Quote
Hard wired smoke alarm in NYS ADKstorm Electrical 12 04-30-2009 09:58 PM
Just to confirm, no GFCI needed for hard wired pool pump..right?? Al the Diy guy Electrical 6 02-10-2008 12:28 PM
Over the stove microwave/hood range helpless handyman Appliances 3 12-27-2007 08:33 AM
Gas stove top/oven conversion to combo range... Leikela Appliances 1 03-08-2007 06:16 PM
Hard wired fire alarms keeping going off sdgoss Electrical 6 11-09-2005 08:57 PM
