Change Top Spray Bosh She58c06uc 48 - Appliances - DIY Chatroom Home Improvement Forum
Old 09-02-2009, 07:21 AM   #1
Unhappy
Change top spray Bosh she58c06uc 48
Hi How to replace this part (see picture) ? On my dishwasher (Bosch she58c06uc 48) top part is broken so I really need to replace top spray, but they will send me whole thing. Thanks
edulinka is offline   Reply With Quote
Old 09-02-2009, 07:37 AM   #2
Looks identical to my SHU43. Two screws at the bottom of the tub, you may need a torx driver, same size as the screws on the inside of the door.. The arm seems to flex away from the top of the DW so is not connected there. Be gentle. Look at the bracket mid level at back when your baskets are pulled out. It may be connected to the back wall by hidden screws or a clamp where the three "knobs" are on the arm.
Chemist1961 is offline   Reply With Quote
Old 09-02-2009, 09:19 AM   #3
More details on middle section
Is any way just to replace from middle to top (just top section) and not whole thing? How it is connects in a middle(clamp where the three "knobs")?
Old 09-02-2009, 09:32 AM   #4
Looks like but I haven't pulled mine apart to check. You will know when the new part arrives though.
spray or brush baseboards? mathdan Painting 20 06-05-2015 09:41 PM
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
spray foam - headers and flat ceiling biglumber35 Building & Construction 2 05-01-2009 11:40 PM
Spray or Hand Workaholic Painting 2 01-24-2009 07:38 PM
