Central Vacuum Plumbing - Appliances - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 03:25 PM   #1
Central Vacuum plumbing
Previous owner decided it would be nice to take the central vacuum. I installed a new one but the short little flex that was there wont reach the new inlet.
I know its not recommended but can I just go to home depot and use regular home dept sch. 40 pvc elbows and such? Just order a few more feet of the flex from online?
Just looking for the simple option. Thanks
amdspitfire is offline   Reply With Quote
Old 03-07-2013, 07:03 PM   #2
Rewards Points: 22
SCH40 won't work. It's a different size. I think Home Depot sells the correct tubing. Unless your manual specs a flex tubing you can use hard pipe.
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
amdspitfire (03-22-2013)
Old 03-07-2013, 08:02 PM   #3
Rewards Points: 1,466
I'm sure there's a CV dealer somewhere close to you.
All you would need to do it right is three sweep 90's, no more than a couple feet of pipe, and some PVC cement.
Better to use hose clamps on the piece of flex.
ktkelly is offline   Reply With Quote
Old 03-07-2013, 08:07 PM   #4
Rewards Points: 6,652
Step back and take a wider shot of the setup. BTW, you can use a #20-22 Beanies, or if you have a spare telephone jack box laying around, the biscuit plates come in handy for stuff like this, for the wiring for the vac.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 03-08-2013, 08:36 PM   #5
I thought 2'' meant theyd match but saw the diff here:
I live in Bay Area, CA and can't find any local CV dealers. Gotta keep searching or buy online.
The 3 90's and some pipe is exactly what I need.
I'll fix the wiring, thanks for the input
Old 03-08-2013, 08:47 PM   #6
Rewards Points: 22
Try an electrical supply house.
Dan
Old 03-08-2013, 09:01 PM   #7
Originally Posted by amdspitfire View Post
Previous owner decided it would be nice to take the central vacuum. I installed a new one but the short little flex that was there wont reach the new inlet.<br />
<br />
I know its not recommended but can I just go to home depot and use regular home dept sch. 40 pvc elbows and such? Just order a few more feet of the flex from online?<br />
<br />
<img src="https://lh4.googleusercontent.com/-d...0307.jpg" border="0" alt="" /><br />
<br />
<br />
<br />
Up!!!!
raoban111 is offline   Reply With Quote
Old 03-22-2013, 10:59 PM   #8
I got everything rough connected and had a couple questions:
IMAG0417 by amdspitfire, on Flickr
IMAG0418 by amdspitfire, on Flickr
1. Position of clean out looks ok? The vacuum came with it so I figured its good to use and I believe thats about where it should go.
2. Do I glue the coupling to the actual unit too?
3. Regular PVC primer & cement for connections ok?
Old 03-22-2013, 11:40 PM   #9
I would use a Fernco, so if you have to remove the unit, you are not having to cut the pipe off. Now of course, there is nothing wrong with using a coupling that you can undo without cutting, but the fernco is the better option. Also, the manufacturer directions that came with the unit, or available online at NuTone's website, would state what you would do in this situation.
Old 03-23-2013, 06:15 AM   #10
Rewards Points: 22
The last fitting to the unit does not need to be glued. Looks like you have a nice tight piping job.
Dan
new basement plumbing karenfazeng Plumbing 1 07-02-2012 11:35 AM
Under-slab or In-slab plumbing? CplDevilDog Concrete, Stone & Masonry 1 06-13-2012 06:43 AM
Shower Plumbing Set Too Far Back?? plumb_confused Plumbing 2 06-01-2012 07:23 PM
Central Vacuum Wiring Rough-In ebayhoey Electrical 2 07-10-2011 03:08 PM
central vacuum amba Electrical 1 03-13-2011 05:15 PM
