Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-12-2012, 06:45 PM   #1
Central vacuum issue
I have recently installed a central vacuum into our new house which came with 3 outlets and a vacuum pan roughed in. The vacuum worked flawlessly for about a week but now it won't turn on using the switch on the hose. I have tested the wiring and its fine so I think the issue is either with the vacuum itself or the hose. The weird thing is though that opening the vacuum pan will still turn the vacuum on. Also if I put the hose in the outlet sideways jumping the connectors it will turn the vacuum on but will obviously not be controlled by the switch.
So far to trouble shoot I have:
confirmed the hose is properly seated in the outlet
checked all wire connections are good
hooked a spare outlet up directly to the vacuum with a short piece of wire and it still wouldn't turn on
tried a second hose and it still wouldn't turn on
The vacuum is a Kenmore 600 air watt central vac built by Electrolux.
Any suggestions would be appreciated.
omgwtf is offline   Reply With Quote
Old 10-13-2012, 12:22 AM   #2
You might start by putting your location in your profile.
This has me somewhat mystified.
Your floor dustpan is working, as are all your inlets if you jump them.
Your hose won't work, nor will another.
The only conclusion I can come up with is that both of your hoses have bad switches/connections.
We know that isn't the case.
I would start by switching out the inlets with new ones. Maybe the plugs have been ruined somehow. Maybe the hose plug doesn't fit in properly anymore.
Strange how 3 inlets stopped working with the hose, but they still work if you jump them.
I have had some problems with the hoses not working. In such a case, I have first cleaned the rings around the male part of the insert. Secondly, I have disassembled the grip of the hose assembly and cleaned it.
I have also had some problems with the sensors on the inlets. I have solved this by cleaning them. I also push at them a bit.
Let us know how you come out and hopefully others will chime in as well.
cleveman is offline   Reply With Quote
Old 10-13-2012, 06:08 AM   #3
creeper's Avatar
Is it dead with and without the powerhead. If its just the powerhead, some models have a push button right on top of the head itself.
Do you change the bag lately. Forgot to reinstall the filter? or line up the bin properly?
Another outlet some left slightly open
Clean the sensor on the outlet ^^^^
creeper is offline   Reply With Quote
Old 10-13-2012, 10:15 AM   #4
I have tried changing 1 of the inlets and it still didn't work.
And yes this is both with and without the power head.
I'm not a central vac expert by any means but this has me stumped.
I have a sears technician coming out on the 23rd as the vacuum is still under warranty but I'd like to figure it out on my own.
Old 10-13-2012, 12:28 PM   #5
Yes I am in Canada and the vacuum is a rebranded Electrolux. I will try and post pictures soon.
Old 10-13-2012, 11:30 PM   #6
If the technician is coming on the 23rd, I hope you didn't buy your toilet from the same place.
Old 10-14-2012, 09:05 AM   #7
Yeah I know it's a long time to wait but it still works just not the way it should. I may just take the hose in and see what they say.
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 09:19 AM
central vacuum amba Electrical 1 03-13-2011 06:15 PM
no wiring for the central vacuum mgamike Electrical 16 01-03-2011 04:53 PM
Central Vac problem strongbow Electrical 4 10-23-2010 09:49 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 04:14 PM
