-   -   central vac stopped working (http://www.diychatroom.com/f47/central-vac-stopped-working-75378/)
wendl 07-04-2010 01:27 PM
Hi - central vac is completely dead. Checked breaker, plug, filter bag and have pressed the Reset button...still nothing. Anything else I should be checking....many thankshttp://images.ibsrv.net/ibsrv/res/sr...lies/smile.gif
nap 07-04-2010 03:33 PM
do you have some way to actually check for the presence of voltage?
How does your turn on? Are there switches at the doors for the hose connection (hidden switches generally) that automatically turn the vacuum on when you plug in a hose or open the door or some other actions or is there some manual method of having to turn it on?
Gary in WA 07-04-2010 09:06 PM
Did you read the manual? As mentioned--- have any power? Check the filter/bag for fullness? Is the plug-in on a GFCI (as required in a garage)? The intake at the unit should work even if other remote ones don't.
Be safe, Gary
