Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-02-2012, 04:47 PM   #1
Central vac installation
It is roughed in, but when I took the cap off all I see is one looped wire rather than the two I expected to see. Can i cut this wire?
RachelCooper is offline   Reply With Quote
Old 01-02-2012, 08:06 PM   #2
Moderator
No, that is standard install. Just gently pull each side, one at a time, one may be the end. Leave it long- 12" to make attachment to the faceplate easier. Test it before installing the faceplate...... It is one group of two 18g. wires. OR: It may loop at the outlet and run to the next outlet, then cut in the middle and attach like-colored/stripped wires to the faceplate.
Gary
Clothes taking longer to dry?
Old 01-02-2012, 09:53 PM   #3
Thanks Gary! So we did that...and now we're at the last step, the low voltage wire connectors...I dont even know where to start. It looks like on other models this isn't a problem but we're working with a Hoover and it appears to be a problem for others as well...any more advice?
Old 01-04-2012, 06:28 PM   #4
Moderator
Which model number do you have?
http://www.google.com/search?client=...iw=830&bih=466
Gary
Old 01-06-2012, 07:33 AM   #5
The wires are low voltage and interchangeable. If you have multi strand telephone wire, i.e. 4 or more colored stands, I suggest running a matched color pair, if you can see where all wires terminate elsewhere in the house. If it is a 2 strand wire there is no requirement for left or right at your INLETS or the vac.
Be sure not to lose the springs under the terminal screws on the inlets when wiring. Only back the screw out enough to loop the wire fully around. If you have metal mounting plates in the wall be certain there is no excess bare wire from your terminals contacting the plates when you install the inlets in the wall.
The short screw if one is included with your inlets goes on the pipe side so as not to pierce the pipe in the wall. IE on the top floor, the pipe would be below the inlet, so short screw is used st the bottom.
When you mount the unit leave at least an extra 36 " of slack in the wire, coil it around a small screwdriver or pencil like a phone cord. This will provide a stress free terminal in case the unit is ever moved.
When done, the system is low voltage, you can jump start it without a shock by using a quarter to short across the terminals at each inlet. Listen for a hiss or flutter at each inlet when the door pops shut. Ideally the door should swing up, to prevent strain from the weight of the hose. If there is any noise as the machine shuts off, back out the inlet screws and adjust for flush fit to the wall.
One more tip, many Cvac INLETS have a narrow rubber O ring on the mounting plate in the wall, which creates an air tight seal to the neck of valve. When the valve is inserted, I wet the O ring with a drop of saliva on my finger tip so as not to pop the O ring out of place... Happy cleaning
Chemist1961 is offline   Reply With Quote
Central Air Conditioning installation Hrlyguy HVAC 1 08-02-2009 08:07 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Central Air Installation vs. Oil Furnace shnfldr HVAC 6 06-20-2008 07:49 AM
Central AC - Full Installation alex333 HVAC 2 06-14-2008 07:01 PM
Central Air Installation Question ??? WorkOnIt HVAC 3 03-07-2008 05:04 PM
