Central Vac - Appliances - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 12:28 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 226
Central Vac
I Have a Zenex model 275, we have two inlets and the hose does not work properly in either, when we plug it in straight it does not turn on, but if we twist it on either to the left or right slightly, it turns on. The switch on the hose does not turn it on or off, we have to untwist the hose to turn off.
Is it the switch??
Barry
Barry J is offline   Reply With Quote
Add Third Timer Switch to Central Exhaust Fan MaxSteel Electrical 4 11-01-2011 03:08 PM
Central Air Conditioning running all day quaildog HVAC 26 03-14-2011 06:02 AM
Central Vac problem strongbow Electrical 4 10-23-2010 09:49 PM
Worth it for Central Air John84 HVAC 13 07-21-2009 07:00 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
