Ceiling Fan Will Not Change Speeds. - Appliances - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 01:24 PM   #1
ceiling fan will not change speeds.
could you tell me what to look for. fan will only run on slow speed
papabear3 is offline   Reply With Quote
Old 03-14-2012, 08:11 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
speed switch likely bad unless you have a remote controlled unit
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-16-2012, 10:09 PM   #3
remodeling pro
Sounds like the selector switch is bad. You can get a replacment at the local big box or most well stocked hardware stores. Make sure your connections are solid when replacing; the little wire nuts used from the factory of usually pretty trashy.
BE SURE TO TURN OFF CIRCUIT FAN IS ON.
troubleseeker is offline   Reply With Quote
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 07:52 PM
Another 2x6 cathedral ceiling juststarted Building & Construction 17 11-22-2011 04:27 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
