Ceiling Fan Light Works, Fan Doesn't - Appliances - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 01:26 PM   #1
So this morning I threw a blanket to my bed, but it hit the pull switch, and the pull switch got in the fan (I think thats what happend, could just be the blanket made something loose). Now the fan light works, and when I turn the switch on from the outlet, I can hear the electricity surging, but the fan doesn't turn, even when I use the pull switch. Thanks for the help!
ineedhelp1 is offline   Reply With Quote
Old 03-20-2012, 01:39 PM   #2
Rewards Points: 13,300
The switch to contol the fan is a cheap plastic one and often go bad.
Kill the breaker to that fixture, remove the light kit and the see who many wires are on the fan switch and go buy one whith the same number of wires.
When replacing only undo one wire at a time to make sure you do not get the wires crossed.
Old 03-20-2012, 01:44 PM   #3
But why would I buy a light kit if the fans broken? Or am I getting my terms mixed up? Sorry, I am not much of a handyman. Also the pull switch that (may or may not) have gotten stuck in the fan was the light pull switch, and the light can still be controlled and works.
Old 03-20-2012, 02:08 PM   #4
I never siad to replace the light kit. To get to the fan switch you have to remove the light housing, and the cover or trim ring housing the fan switch.
There's 3 switchs in a ceiling fan in most cases, one with two wires for the light, another one with 2 wires to change the direction of the fan, and the one I'm suggesting you replace and one with several wires to control the fan speed.
Tags
ceiling fan , fan doesn't , light works
Question concerning a ceiling light and grounding mTorbin Electrical 5 02-07-2012 09:23 AM
5000k Light Blulbs for Ceiling Fan Fixture (clean white light for living room) cmf0106 Electrical 10 01-12-2012 11:04 PM
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 01:09 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
