Ceiling Fan Installation Advice From Expert Ravee Patel - Appliances - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 08:42 PM   #1
Smile
Ceiling fan installation advice from expert Ravee Patel
Is is difficult to install fans? This mate (Ravee Patel) on a home improvement shows on TV makes it look so easy. I have no experience with this, and wanted outside advice. Thanks
pologuy1 is offline   Reply With Quote
Old 06-08-2011, 01:50 PM   #2
Talking
Having my sister install the fan, while i do the flooring. knock one off the list LOL
Old 06-10-2011, 10:48 AM   #3
Trying to save a little money. How much would on average cost to hire someone?
Old 06-11-2011, 09:57 AM   #4
Ironlight's Avatar
It's not that hard. The main issue is ensuring that there is adequate support where you install it and that the installation follows the specification for the fan, and then balancing the blades if necessary to prevent wobble. I've done a few of them and it's not rocket science. Depending on the size of the fan and the size of your sister, however, it might be difficult for her during stages of the installation.
Also, if your parents are still alive and there is a sizeable estate at stake, consider the wisdom of having your sister install a large motor with blades that hangs over your head.
Ironlight is offline   Reply With Quote
Old 06-11-2011, 10:17 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
How hard it is depends on what you are starting with and what you want.
Are you replacing an existing ceiling light? or is this a total new install (meaning you have to run electrical cable)?
Does your planned fan have a light kit?
Will you use the pull chains to control the light and fan? or do you want separate switch control? or do you want to use a fan remote control?
Answer the questions and give us the details of your plan
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 06-23-2011, 11:59 AM   #6
I am not replacing an existing ceiling fan. its a totally new install, including electrical. and yes, the fan does have a fight. Yes to separate switch control, and no, no remote
thanks so much rjniles
Old 06-23-2011, 11:59 AM   #7
lights, not fights... lol lol lol
Old 06-23-2011, 12:25 PM   #8
A "Handy Husband"
rjniles's Avatar
Basics:
Power to wall mounted 2 gang switch box, install 2 switches (1 for fan, 1 for light), 3 wire cable to location of fan. Install fan rated ceiling box. Connect wiring and hang fan.
Does any of this sound like you can do?
Were will you get power supply? Do you have access from above to run wire and install ceiling box?
Tags
ceiling fan , patel , ravee , ravee patel
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Ceiling Fan Installation Problem ejbende Electrical 6 09-01-2009 09:35 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Hole saw advice for ceiling boxes CowboyAndy Electrical 39 10-06-2008 06:02 PM
