Caught Blanket In Fan Blades, Now Fan Won't Spin... :( - Appliances - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 07:58 PM   #1
Hello,
So our son has a fan in his room and a bunk bed. Long story short, he decided it was a good idea to stick his blanket into the spinning blades.
Now, his fan won't spin. It is still easy to turn the blades manually, but it won't turn automatically. The light still works.
Is this possibly fixable or do I need to replace the whole fan unit now?
Thanks for your help!
gamingneeds is offline   Reply With Quote
Old 06-26-2013, 08:06 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,786
Off hand.... I know of no reset or trip... I think it's adios.
Maybe a sparky has an idea.... but new is less pricey than repair.... even if there was a repair anywhere.
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
oh'mike (06-26-2013)
Old 06-26-2013, 10:18 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
Did you pull the chains?
Old 06-26-2013, 10:18 PM   #4
Renovating My Land Yacht
Rewards Points: 616
This is where you say thank God he tried to put the blanket in and not his arm or something that could kick back on him.
Hope you get it fixed.
forcedreno2012 is offline   Reply With Quote
Old 06-27-2013, 12:02 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Some of the fans I know they will have a thermal fuse in there so once you bind them up the moteur will get very warm and it will pop the thermal fuse so that way it will not catch on fire ( I know our European verison do that with some of the fans over here.)
If that is not a expenisve item why not get the other one ?
Merci,
Marc
Old 06-27-2013, 08:10 AM   #6
Bill Kearney
Rewards Points: 1,174
FYI:
http://www.ceiling-fans-n-more.com/c...capacitors.php
http://www.ceiling-fans-n-more.com/c...ng-and-FAQ.php
They also have a forum for questions
wkearney99 is offline   Reply With Quote
Frigidaire Affinity front loading washer 2006 model-won't spin final spin? imola ghost Appliances 9 10-23-2015 04:23 AM
Supporting a spinning type axle, cutting down its ability to spin jratftcc Carpentry 2 05-16-2013 06:35 AM
Ridgid Saw blades kevsprojects Tools 12 03-17-2012 07:16 AM
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 12:39 AM
Washing Machine Not Reaching Max Spin Shelley Appliances 2 11-30-2008 09:12 PM
